Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ? about an electric fan for PU.
Old 08-20-2005, 04:08 PM
Blazin72's Avatar
Blazin72 Blazin72 is offline
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Did the short pumps come before the long pumps? I always forget. I wanna think that his truck would have come with a long pump from the factory but I cant remember.
Electric fans are sweet though, I use a dual setup on my truck and they work great. If you install an automatic switch with the fan you dont have to turn it on and off all the time. I think automatic switches run anywhere from $35 to maybe $70 depending on what you buy. Then just wire a toggle switch in somewhere on/under the dash that you can use in case the auto. switch fails or you need the fan to run constantly.
I rewired mine with a painless kit too but I didnt use that wire. It's tiny. It would probably work if you use it to switch a relay but I doubt it will carry enough current to run a fan.
