Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ? about an electric fan for PU.
Old 08-20-2005, 08:03 PM
Streetmaster Streetmaster is offline
ThanX guys for all the responces, and yes the summit chrome water pump, is the long version. The only problem i was having with it was the fact that it is bulked up to much in the front, because i guess its a high flow pump, and when i placed a two belt pulley on it, the pulley would rubb against the front of the pump. So i had to put shims behind the pulley, and that would put the alignment of the pulleys way off. So i said the h#ll with it and i bought a new stock pump, and problem solved.
