???? about epoxy primer/sealer - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-01-2006, 07:22 PM
I found a real good deal on some epoxy primer/sealer its made by Kirker has anyone ever used this or should I go with dupont or house of color
Old 11-01-2006, 09:36 PM
Glennk's Avatar
Kirker
I have used their epoxy primer and I like it. It sands well after 2 or 3 days and It's all I used on my coupe. No high build or sealers.. just the epoxy and sanded it like it was build primer...JMHO.......GlennK
Old 11-01-2006, 11:08 PM
i use it all the time it is very good!!excellent corrosion resistant, and it does sand like butter, it is as good as any epoxy ive used as far as price. it is actually better in my opinion than some of the higher dollar ones, give it a try you will like it, mike.
Old 11-02-2006, 03:21 AM
adtkart@aol.com
All I am going to say is do a search on this forum for Kirker. It has been discussed, at length several times. Then decide if the cost savings is worth it to you. Also remember that the primer is the foundation of any paint job
Aaron
"Good houses are never built on gravel foundations"
Old 11-02-2006, 04:59 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
Old 11-02-2006, 06:18 AM
thanks for all the replies I going to get some and try it out
Old 11-02-2006, 05:55 PM
adtkart@aol.com
You might as well go ahead and check out the paints and other supplies too. That way you won't have that much money in the job, when you have to do it again.
Aaron
Dura Glas then epoxy robs ss Body - Exterior 21 11-21-2005 07:18 AM
Marine Epoxy Primer? rlackey Body - Exterior 10 03-24-2005 04:14 AM
Barry, epoxy adhesion testing? baddbob Body - Exterior 21 03-20-2005 09:12 PM
applying epoxy - gun question Dubz Body - Exterior 3 09-15-2004 07:02 PM
Urethane and Epoxy Primers bmech211 Body - Exterior 1 04-17-2004 05:04 AM
