Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ???about exhaust pipe on 2.2 s10
Old 05-07-2009, 08:40 PM
Malibucass Malibucass is offline
Originally Posted by Robbie
was wondering were the exhaust pipe bolts to the exhaust manifold ,about 4inches of the pipe is made of some kind of flexable material,and it is leaking, can this part be replaced,or will i have to replace the whole pipe,it runs from the manifold to the catalytic convertor.
Thanks Robbie
working with exhaust for the last 22 years my answer would be yes you can replace just the flex if the pipes are good and you have some welding skills...the is there to relieve tension from engine vibration or movement, A common cause of failure is BAD MOTOR MOUNTS...Make sure to check them...
