Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ???about exhaust pipe on 2.2 s10
Old 05-07-2009, 08:54 PM
Robbie's Avatar
Robbie Robbie is offline
Last journal entry: nova
motor mounts aint the problem,blown head gasket is,after taking the head off i saw were it has been leaking at,and were would i buy this part at,(dont tell me ebay )
Originally Posted by Malibucass
working with exhaust for the last 22 years my answer would be yes you can replace just the flex if the pipes are good and you have some welding skills...the is there to relieve tension from engine vibration or movement, A common cause of failure is BAD MOTOR MOUNTS...Make sure to check them...
