-   -   ???about exhaust pipe on 2.2 s10 (http://www.hotrodders.com/forum/about-exhaust-pipe-2-2-s10-158179.html)
Robbie 05-07-2009 08:19 PM
was wondering were the exhaust pipe bolts to the exhaust manifold ,about 4inches of the pipe is made of some kind of flexable material,and it is leaking, can this part be replaced,or will i have to replace the whole pipe,it runs from the manifold to the catalytic convertor.
Thanks Robbie
Chevrolet4x4s 05-07-2009 08:33 PM
woven stainless? Flex pipe I believe they are called. They can usually be found on ebay.
Shane
Malibucass 05-07-2009 08:40 PM
Thanks Robbie
working with exhaust for the last 22 years my answer would be yes you can replace just the flex if the pipes are good and you have some welding skills...the is there to relieve tension from engine vibration or movement, A common cause of failure is BAD MOTOR MOUNTS...Make sure to check them...
Robbie 05-07-2009 08:54 PM
motor mounts aint the problem,blown head gasket is,after taking the head off i saw were it has been leaking at,and were would i buy this part at,(dont tell me ebay :) )
SSedan64 05-08-2009 03:54 AM
Robbie that's usually the one piece places like AZ & Advance don't carry and if they do it's connected to the Head pipe & expensive. May have to get it from a muffler shop. Or as mentioned above Evilbay.
