About to get set of 882's redone...suggestions? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2003, 07:55 PM
Post About to get set of 882's redone...suggestions?
Well, I am gonna get Z28 springs put on them.
Gonna have them cleaned up and magnafluxed and all that.
You guys have any comments or suggestions? Something else I should have done to them? Trying to keep it as cheap as possible. Port job is out...cuz $350 for a port job is more then I want to spend..
Old 03-12-2003, 08:00 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Post
Th exhaust side of these heads are the weakest point, if you can afford just the bowls than your power ahead. If not then just the springs will net you a reliable(if you don't overheat them) 300 horse machine with the right cam selection.
Old 03-12-2003, 08:04 PM
Post
Oh yeah, they don't flow well above .450 stock untouched so any more than that will be overkill.
GOOD Luck with them. They are one of my favorites for cheap.
Old 03-12-2003, 08:15 PM
Post
Yea,
My cam is .464" lift but I doubt Ill see much more then .400" on the street anyway.
Yea, i checked the flow numbers and they seem to do pretty good up to .400". They are the matching heads to my block that I built. Just need to get it done, so I am using them. Good budget head and I already have them.
Old 03-13-2003, 04:59 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
[quote]Originally posted by TheZaZ:
<strong>Yea,
</strong><hr></blockquote>
Just to clear up an apparent misconception....Cam lift is not dynamic. It is the same at idle as it is at 5000RPM.
Chris
Old 03-13-2003, 04:22 PM
Post
Yea, Im retarded.
Dont know what the hell I was thinking when I posted that. LOL.
Old 03-13-2003, 04:58 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Post
Why not port them your self and save some money. Check this site out if you feel like trying it.
DIY Cylinder Head Porting Guide
http://www.eastwoodco.com/
Luv the smell of NITRO in the morning.
Old 03-13-2003, 07:14 PM
Post
I'm with 1bad80. just don't try an over kill your first time in a head. keep it a simple bowl blend and gasket match. opening them up alot probably wouldn't be worth it anyway with that cam.
Old 03-13-2003, 11:07 PM
NorthStar's Avatar
Post
<strong>Well, I am gonna get Z28 springs put on them.
You guys have any comments or suggestions? Something else I should have done to them? Trying to keep it as cheap as possible. Port job is out...cuz $350 for a port job is more then I want to spend..</strong><hr></blockquote>
Might want to think about getting the rocker studs pinned too and $350 for a simple pocket port is somebody ripping you off.
Old 03-14-2003, 05:01 AM
TurboS10's Avatar
Wiki Edits: 2
Post
I am with the other guys on the port job. Cylinder head porting is something any hotrodder should try. After I learned, I give every set a pocket port and gasket match at least. Go for it.
$350 might be a little high for a pocket porting, but if they are doing gasket match also or anything else it is not bad at all. Many people pay $1000 for a race port job. You gotta figure $50 per hour or so.
Chris
Old 03-14-2003, 06:09 AM
1BAD80's Avatar
Wiki Edits: 2
Post
Its not had to redo the rocker studs either. I wrote a post on how to do it. I'll have to find it or redo it for you. Its very easy and worth a try yourself.
Old 03-14-2003, 06:46 AM
Post
Yea,
the $350 for the port job seemed high to me too but I think the guy does the whole damn head. Everything. Has to be cuz that just is a little steep.
