? about the groove's on the input shaft. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2004, 11:21 PM
Have'in some trouble with finding the groove's on my saginaw 3-speed because im not sure if there supost to be right there on the end of the shaft were the clutch ride's, or how deep the groove's are. Or if the groove is closer toward's the bearing retainer because there is one that is about an 1/8 in wide that's not real deep, it can just be felt with the finger tip,and it's back toward's the bearing container on my saginaw 3-speed. (Please help with the brain fog)
Old 06-19-2004, 02:56 AM
left to right: no rings, 2 rings, 1 ring (these are Muncies, but you get the idea)
Old 06-19-2004, 08:48 AM
WOW great job on the foto, you really cleared that much for me. The biggest reason that i was confused about this is I called the guy at D&L trannies and ?'ed him about the groove's beause my saginaw 3-speed does'nt have any groove's on the front end of my input shaft, it show's that my tranny has the 2.85 first gear ratio, but i told him that my input shaft also has 18 teeth on, and then he said that i had a 3.11 gear box witch i think is supost to have 2 groove's on the end of the input shaft. Another ? is i wonder if they ever used the 2.85 first gear ratio 3-speed behind an inline-6 with a 3.40 gear out back in a 3,900 lbs GMC short bed. (I guess im just discombobulated or something)
