? about modifying/ updating stering
I have a little issue guys with my new motor and the steering. The problem is most likely an easy fix but im new to this and not sure what i can and cant do to fix it. I have a 1949 for pickup and put a 302 motor in and the drive side headers wont fit due to the old stering box. So what can i do to fix this? Can i put a newer steering box in and mount it somewhere else mabe lower on the frame or on my axle? Any help would be greatly appreciatied
Not the answer you are looking for B U T You can move the engine/transmission over ... Ford did the very same thing in a lot of it's vehicles from the factory. I have the SBC in BOTH of my 32 Fords moved over to the right side about 3/4 ths of a inch ... to gain clearance for the steering.
Deuce ...
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
i could it would be a pain but something to always consider
The Ford Econoline Vans had the engine/transmission moved over at least 2 or 3 inches ... with no adverse effect.
Dodge did also..
MY 51 f1 jag front suspension
You could get a power steering box or a manual box
from a toyota pick up--they fit the 48-52 & maybe newer ford pick up's. You could also get a older jag front end pretty cheap that would give you power rack & pinion--coil springs disc brakes & it is an almost bolt in job. I only paid $100 for mine & i have a 51 ford f1 pick up.Where else can you go & get all of that for $100--mine came off of a 1977 jag
| power stering question? | alle4901 | Suspension - Brakes - Steering | 1 | 10-23-2008 04:13 PM |
| modifying a fwd cars strut tower for turbo clearnce - advice needed | lowROLLERchevy | General Rodding Tech | 4 | 03-10-2006 11:20 PM |
| will a power stering box from 83 trans am fit 68 chevelle | 4onthefloor 2 | Suspension - Brakes - Steering | 4 | 02-13-2005 10:52 PM |
| power stering | martinpalma | Suspension - Brakes - Steering | 5 | 07-29-2004 10:22 PM |
| Updating 55 Olds Ft End | Juans55Olds | Suspension - Brakes - Steering | 1 | 09-17-2003 08:38 AM |
