? about return line at tank on EFI system - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2013, 08:04 PM
I have a fuel tank that measures about 7" thin X 19" high X 28" wide. The return line is going into the top. I'm thinking the tube should go down near the bottom. This would cut down on noise and help cut down on fumes caused by splashing. The tube would be about 6 inches from pickup tube so heated return fuel should not be a problem. Does this sound right?
Chevy 5.7L TBI fuel tank venting and return line Infinite Monkeys Engine 2 01-20-2012 04:00 PM
plumb a return line in a stock tank? defilade Engine 2 01-12-2011 05:27 AM
Holley fuel pump, return line or not to return line??? JD's camaro Engine 1 07-16-2010 05:17 PM
Short EFI return system? ForceFed86 Hotrodding Basics 4 03-15-2010 04:37 PM
EFI return line valve oldred Engine 6 08-24-2007 05:53 PM
