Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ? about what to set the timing at on a 350 sbc.
Old 09-25-2005, 12:46 AM
xntrik's Avatar
xntrik xntrik is offline
Save a horse, Ride a Cowboy.
From thread "383 stroker" 24 Sept 05
re: 383 stroker
Originally Posted by waltnardo
I've installed a 383 stroker in my 1983 Malibu wagon. I don't know how to set the timing. The cam that I have is a comp CS X4 254H - 11 which has a .447 intake & a .462 exhaust. Can anyone tell me what I should set the timing at?
ok You tell us nothing about your set up, only about your cam, and then somebody says 12*, so I guess you mean ignition timing not cam timing.
Nothing like guessing away 60 hp/torque. huh?
12* initial is a good starting place , considering your altitude and that we don't know anything about your set up.
centrifugal should start at 1000 rpm and come in about 24* at 3000 rpm, lower will probably be too aggressive.
vacuum should do about 12*, variable as per 60 mph cruise vacuum minus 2. recalibrate for highway load.
Cam timing should be cam company spec, dynamic cranking compression to maximum then advanced 2-4*.
Good luck, you need it.
