? about XE262 cam compared to others - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2009, 11:54 AM
Hello, I an building a chevy 350,(Bore .30) I plan to hoop it abet with
better heads,intake and carb. and hedders.
I looked at the compcam chart for the XE262, and would like to know
if this cam is reliable,to last. I heard it jumps off the seats and back
pretty fast. Is there another cam that would do the same job as the
xe262, but easier on valve train?
Thanks
Old 10-01-2009, 11:59 AM
Greg T's Avatar
www.krusinklassics.net
I used to use nothing but comp cams but I have changed my attitude since they've been flattening lobes. My son happened to get a good one a couple of years back and it is still running as I am sure many others have on this board. But I've seen some horrific failures in comps cams as of recent. I am shying away from them for awhile. I like Isky and Crower so far. Not a flat lobe in the bunch yet.
You may want to check out the Voodoo series from Lunati. Lunati is some very nice stuff.
Old 10-01-2009, 07:02 PM
sapsZ28
I have a xe 268 in my 350 4 speed 80 Z28 heads fully p&p 800 cfm edelbrock carb,rpm intake msd streetfire ignition,Man I tell ya this set up is the bomb,it flattens every time I hammer it, car goes sideways in the first 2 gears at any throttle from 1500 rpm &up go with a roller top end and matching springs your valves will thank you.
ps 13.2@101mph 4000lbs car & driver with 3:42 rear stock suspension and dunlop radials this baby is so fun to drive next step drag radials and a 5 speed. good luck .
Old 10-03-2009, 03:45 PM
Thanks
If you are worried about the XE series of cams, with the faster ramps, check out their single profile cams ie 262H, 264H and 268H.
Old 10-03-2009, 07:02 PM
Overdriv's Avatar
I am running a Comp XE 274 in a 406 with no problems at all. Engine makes awesome power in low and mid range. After 5500 it starts to flatten out, but still pulls good to 6000, where the rev limiter is.
Cam button length/clearance..? mrdreex Engine 1 04-12-2008 10:17 PM
I need cam help 355s10 Engine 5 03-16-2008 05:34 PM
What cam specs work well with centrifugal Superchargers? hotrodf1 Engine 1 09-22-2007 04:21 PM
Help Me Pick A Cam Canadian Charlie Engine 2 11-16-2005 01:11 PM
Roller Cam Help!!! Vsanthos Engine 13 10-31-2002 04:29 PM
