Abrasive Blaster - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-16-2010, 07:56 AM
Ratdoggy's Avatar
Hammer torch chisel...
Last journal entry: Got the wheels on
I have the 780 top load from Tip Tools and the vacuum thing. It works great and it wasn't really expensive. Not too big and not too small.
  #17 (permalink)
Old 06-18-2010, 09:05 AM
I am about to cut up a 55 gal drum to build my own. For the window, I was going to make a reel-to-reel mechanism where I could wind the window protector by foot or knee bump control so I don't have to stop to clean it. I am thinking some of those HF led drop lamps will fit the bill for lighting quite well. I am thinking chem gloves and denim jean legs for the arms?
Should I build it as a siphon or for pressure? Very different designs I know. My compressor is about a 10 gal, 2 cyl Sears.
  #18 (permalink)
Old 06-20-2010, 06:12 PM
Riot Racing's Avatar
Last journal entry: Por 15
So I put mine together and fired it up. THe results are CRAP. I think The abrasive media I am using is too soft. The only media they sold was the glass bead stuff.
FOr the rust removal I am going to need some heavy duty media, even if it kills me!
  #19 (permalink)
Old 06-20-2010, 09:00 PM
Ratdoggy's Avatar
If you're having problems with the 780 call their tech line.
I've never had a problem. Maybe for heavy rust you should use aluminum oxide.
  #20 (permalink)
Old 07-02-2010, 12:48 PM
My rust is not really that heavy. I switched to steel grit and it works, but the spray pattern is so small that this is going to take a lifetime.
The vacuum on the setup does not suck very hard so the media still gets everything. In fact, i tested blasting without the vacuum on and its the same...
I bought a deadman valve to try that instead of the gun style.
It that doesn't work.
I am going to buy play sand and blast that and use an empty parking lot. That way I don't care about the cost of the media or the mess.
Ill wear a good mask and try not to blast too long.
Has Anyone Built A Soda Blaster? Old Fool Body - Exterior 11 08-17-2008 06:06 PM
Abrasive Blaster SHIFTY101EASY Body - Exterior 19 02-04-2007 06:29 AM
Abrasive blaster 67Chevy_c10 Garage - Tools 7 06-05-2006 01:31 AM
msd blaster 3 vs. blaster 2 coil kidmopar66 Electrical 2 03-02-2004 02:23 PM
Mallory coil vs. MSD Blaster 2 McDeuce Electrical 10 02-29-2004 07:57 PM
