Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ABS 2004 ford sport trac no codes no light
Old 01-31-2013, 01:17 AM
gearheadslife's Avatar
gearheadslife gearheadslife is offline
MentalMuffinMan
Hello.. said truck has the abs that as you slow and are almost stopped, starts pulse'n the brakes lightly..
you can slam the brakes on from 55mph no issue, only when under 5mph and stopping slowly, does it play this game..
Wife drives this, and drive the front brakes to metal on metal.. to the point the inner pad backing(piston side) was almost thin enough to leave the building, now when I did them, I cleaned off the abs senders at the wheel off all the metal shavings,, used brake clean on them.. could a few missed shavings or pieces of rust scale cause this.. at low speed..
no abs light or codes .. no check engine light or codes..
any ideas.. didn't do it for a month after I did the brakes, but now it is.. and is a r.p.i.t.a.
