abs brake pad change - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2008, 03:01 PM
I need to change the brake pads on my 2001 explorer.it has abs. Is there anything i need to do before removing the calipers and brake pads? A friend told me you need a special tool for these brakes. I have done brakes on my cars but never abs. Thanks...
Old 10-15-2008, 05:12 PM
T-bucket23's Avatar
Wiki Edits: 26
No special tools but you should open the bleeder when pushing the piston back in so you dont push dirty fluis and what ever has accumulated in the caliper back through the ABS unit.
Chet
Old 10-15-2008, 05:25 PM
Wiki Edits: 31
if it has rear discs you would need the square caliper pistion tool that rotates the pistions back.. they cost like $5
Old 10-17-2008, 04:23 PM
abs
Thanks for the info. That is probably what my friend was talking about.
i never thought about opening the bleed valve to prevent contaminated fluid from going back into the master cylinder..thanks again...
Ford Galaxie Disc Brake Conversion CrashFarmer2 Suspension - Brakes - Steering 5 04-10-2010 05:52 PM
Brake light problem mightycarlo10 Electrical 6 12-18-2007 06:43 PM
Brake fluid "evaporation" ChevelleSS_LS6 Suspension - Brakes - Steering 1 09-16-2006 03:41 AM
Brake Change ragman64 Suspension - Brakes - Steering 2 04-04-2005 10:38 PM
brake lights stay on.... jmtw Electrical 6 03-06-2005 08:48 AM
