I would not wish to enter into a discussion of if a retro fit of ABS is a good idea or not but one in how one might go about it if one wants to. i think myself fitting the rotors and sensors from a later GM product and getting the ECU for that may work. one may need to fiddle with the programming to get the brake balance correct.
Sam
If you are happy with that single inconclusive article and your experiences - then I'm happy too!! I'll just disagree with you as part of the general public as most people are not serious racers nor was that part of the premise for the discussion. Dave W |
I'm all for staying on topic yet at the same time, I'm all for keeping someone from wasting too much time/money. One thing to make a note of is today's ABS is MUCH more precise than a few years back. Whatever "kit" you find make sure it's up to the task you're asking of it. Will you be able to adjust anything? It may be too sensitive - it may use a smoke detector to engage! On mid 90s GM trucks I remember them having to be reprogrammed for simply putting on larger tires or else they went into useless mode. Adjustability needs to be built in for installing this on a car that doesn't speak the language. Having a sensor watch wheel speed is only part of the package - it must also know when to re-engage the brakes and this could be a problem without programming for a specific weight bias. |
Very true, which is why I figured a mid to late 90's impala would be the best candidate given vehicle weight and brake bias. I still have lots of research to do which may change my donor car choice, but that article basically said what I was already thinking.
I don't want full stability control, just basic abs to keep the wheels from locking in bad driving conditions. |
| S10 Brakes In Chevelle? | strikingthematch | Suspension - Brakes - Steering | 32 | 04-09-2006 04:05 PM |
| 64 chevelle disc brakes | robert1 | Suspension - Brakes - Steering | 1 | 07-16-2005 04:36 AM |
| S10 Brakes on a Chevelle??? | Weimer | Suspension - Brakes - Steering | 5 | 05-23-2003 05:31 PM |
| '65 chevelle disc brakes? | boostwhipped | Suspension - Brakes - Steering | 4 | 12-10-2002 05:09 PM |
| 69 comaro brakes on 64 chevelle | tm454 | Suspension - Brakes - Steering | 1 | 04-02-2002 03:33 PM |
