Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ABS brakes and power steering fluid
Old 08-12-2011, 08:54 PM
66GMC's Avatar
66GMC 66GMC is offline
Get in, sit down, hang on
Last journal entry: Cab Removal
OK.
That is much the same platform as my Pontiac GP(s).
It's fairly common to have problems with the ABS sensor wiring harness. Common enough that the aftermarket has come up with a repair part, which may save you huge money in diag time and OEM wiring harnesses which are very expensive.
I gambled on it being the problem on my 2004 ... and was a cheap starting point. The gamble paid off in my case ... less than an hour's labor and about $60 for the part.
Dorman Part Number 970-040 LH, 970-041 RH.
Also sold in your local NAPA store as BKP (or OES) 641-3359, 641-3360.
Might be worth a try?
