ABS brakes and power steering fluid - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2011, 01:03 PM
Hey all....would a power steering fluid leak affect ABS sensors?
Old 08-12-2011, 05:24 PM
LATECH's Avatar
Not very likely, however fluids like steering transmission and engine oil do cause rubber parts to deteriorate, or to soften and become problematic
Any fluid leaking is a bad thing,you should have it fixed.
Old 08-12-2011, 06:56 PM
Thanks
Yea...thanks...I just bought it and finding out what issues it has. gas gauge does not work either. Brake squeal...don't even get me started...haha.
Old 08-12-2011, 07:00 PM
info
I have read though that dirt, grease etc could cause them to go faulty. Thought maybe the fluid had them too lubricated to respond correctly.
Old 08-12-2011, 07:06 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
What kind of vehicle? (Year, Make, Model)
Old 08-12-2011, 07:41 PM
model
2000 Monte Carlo
Old 08-12-2011, 07:54 PM
66GMC's Avatar
OK.
That is much the same platform as my Pontiac GP(s).
It's fairly common to have problems with the ABS sensor wiring harness. Common enough that the aftermarket has come up with a repair part, which may save you huge money in diag time and OEM wiring harnesses which are very expensive.
I gambled on it being the problem on my 2004 ... and was a cheap starting point. The gamble paid off in my case ... less than an hour's labor and about $60 for the part.
Dorman Part Number 970-040 LH, 970-041 RH.
Also sold in your local NAPA store as BKP (or OES) 641-3359, 641-3360.
Might be worth a try?
Old 08-13-2011, 09:10 PM
Thanks
I think I might just do that. Thanks for the info.
power steering fluid douger456 Suspension - Brakes - Steering 1 01-22-2008 08:02 PM
Hot power steering fluid RAW Suspension - Brakes - Steering 8 04-26-2007 10:00 PM
ATF vs Power Steering Fluid? Jag Daddy Engine 1 12-15-2003 12:22 PM
power steering fluid andybird Transmission - Rearend 1 12-11-2002 12:12 PM
which power steering fluid? andybird Suspension - Brakes - Steering 1 12-11-2002 09:43 AM
