abs brakes on s-10 blazer - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2009, 05:47 PM
ok here is my newest problem ... the s-10 has abs disk brakes from the factory ..... i would like to keep the abs if possible ... the book i have says that the abs is controlled by the tranny input so that they should still work without the computer ... but my gut tells me that its not gonna work ... so do i need to change anything to make it work (im not using the computer im getting rid of the fuel injection and all) and if it isnt gonna work are the brakes gonna work fine without the computer (as in function like normal brakes not abs) or am i gonna need to change alot of crap?
Old 03-20-2009, 07:40 PM
Wiki Edits: 31
ABS has a separate controller.. pretty sure it talks to the main controller for wheel speeds and vehicle speeds tho... in any case, the old S10's have Rear wheel ABS, which is actually more harm than good.. I'd bypass it, with a heavier engine up front, it won't work like it should
Old 03-21-2009, 11:45 AM
thanks man but does that mean that i have to replace everything? or can i just plug the valves on the bottom of the master cylider and leave it at that?
Old 03-21-2009, 05:52 PM
Wiki Edits: 31
just replace the master cylinder with 1 from a pre ABS S10.. order 1 for a early 80's S10.. it's the same truck, just a lot simpler stock ( carb, with only a computer controlled ICS
Old 03-24-2009, 08:59 PM
you can just plumb it bypassing the abs box. might want to run a prop valve. i did this before i switched to a smaller booster and my cpp master cyl. worked fine.
5 on 5" rear end swap in my '62 GMC - 10 bolt vs 9" vs Dana 44 Chuck78 Transmission - Rearend 8 07-22-2008 10:01 PM
1995 S 10 Blazer 4.3 Vortex BrettC49 Engine 3 05-10-2008 06:51 PM
anti-lock brakes helrazr3 Suspension - Brakes - Steering 3 10-20-2007 01:06 PM
Brakes !! NO Brakes !!! Sampson Suspension - Brakes - Steering 9 05-30-2005 08:23 AM
streetrod brakes bigbadchev Suspension - Brakes - Steering 2 03-10-2004 06:02 AM
