ABS Light - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2008, 06:33 AM
ABS Light
My Grandson has a 1993 Chevy Blazer 4.3 Vortec He has two problems first ABS light comes on when speed goe:s above 15mph when it comes below 15mph it stay;s off 2nd problem. Put new TPS on did,t help much noticed if i move the plug around that goes to tps it will change the idle fast move plug idle back down talk to a local mech. he said go to dealer buy a new pig tail for tps held off buying very costly. Any help would be very greatful Than you.
Old 10-22-2008, 12:44 PM
The Maintenance Geek
I seam to recall the ABS isn't operational at that low speed,
the light means there is problem with something in the ABS
hardware, more than likely a wheel speed sensor, or possibly
in the wiring. Check the fluid level just to be sure...
The brake system is still fully operational, it just won't prevent
brake lock-up...
As for the TPS pigtail, I'll assume its a mini Blazer, so try this...
http://www.rockauto.com/catalog/x,ca...,parttype,2624
K
How does a dome light wire up Ed ke6bnl Electrical 2 01-14-2006 08:37 PM
One Brake Light Not Working HotRodMan Electrical 5 12-25-2005 10:51 PM
Trust the timing light or the timing pointer? lluciano77 Engine 6 03-06-2004 02:35 AM
Light Problems like crazy ponybuster Electrical 7 10-14-2003 01:12 PM
a little humor to get through the evening antirice Hotrodders' Lounge 7 08-28-2003 09:36 AM
