Abs question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2013, 02:32 PM
5.0 5.0 is offline
Abs question
Does anybody know what would happen if I put new axles in without an abs ring? I have a 95 mustang gt and I'm thinking about replacing my old ones for some alloys but I don't want to go through pressing on new rings if I don't need them. I know it won't be as safe but I just need to know if the car will brake normaly and not have the wheels lock up for no reason. Thanks for any help!
Old 04-14-2013, 04:17 PM
poncho62's Avatar
Wiki Edits: 5
Your ABS light will stay on........Putting those rings on is not hard....I just tap them on with a hammer....carefuly
Old 04-14-2013, 04:25 PM
5.0 5.0 is offline
So the light would just stay on, you don't think it would cause any normal braking issues?
Old 04-14-2013, 04:44 PM
poncho62's Avatar
Wiki Edits: 5
Not positive....My son in laws Ford Focus had a bad ring...He had to take the ABS fuse out until we replaced the ring, as it did act funny. My 2005 Chevy had a bad sensor and it didnt affect the braking, the ABS just didnt work. Not sure what your 95 might do
Old 04-14-2013, 06:08 PM
5.0 5.0 is offline
What was happening with his car? When y'all took the fuse out did it stop having issues? I'm thinking that if I have problems I'll just remove the sensors. Think that would help? Sorry if I sound dumb but I don't fully understand how all the abs works.
Old 04-14-2013, 06:34 PM
poncho62's Avatar
Wiki Edits: 5
With the fuse in, his ABS would kick in when he braked...When he took the fuse out, it seemed to act as if there was no ABS..no issues..so he told me anyways......but, his ABS and brake light in the dash was on all the time until we put the new sensor ring on.
Old 04-14-2013, 06:46 PM
LATECH's Avatar
Pulling the ABS fuse will disable the ABS function, reverting back to the base system.
A missing tone ring will defaul to the base system, a bad speed sensor will also default to the base system.
Now a speed sensor that intermittently drops a signal or causes signal clarity deviation ....thats a different story.
i have had GM products that activate the ABS at a low speed stop say of 6-7 miles an hour making it difficult to stop on time. I almost drove through a few fences with those. Sometimes a loose/worn wheel bearing can create enough wobble in the signal that is causes an issue like that, also lots of brake grindings, pad material...ferrous buildup .... can skew the square wave generated at the WSS and ske the signal enough to activate the ABS to dump or apply pressure in an undesireable way.
Nothing live driving through the back of the garage or how about the transport guy who loads one on the top deck, just to find out the ABS wont let him stop.....:e vil:
Fact is stranger than Fiction
Old 04-14-2013, 06:57 PM
5.0 5.0 is offline
Thanks for all the help guys! So just to be clear, all I have to do is find the abs fuse and pull it and then there will be no more abs? Y'all haven't heard of any other issues coming from that?
Old 04-14-2013, 07:14 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
My business partner disabled the ABS in his 96 Crown Vic to defeat the traction control that was tied into the ABS system. As said before, the ABS light was on the whole time but there was no other issues he had for the rest of the time he owned the car, which was around five years.
My 96 GT came from the factory without ABS. In the time I owned it, I made one panic stop and it was a hairy situation. It was a 60mph lockup entering an on-ramp when someone passed by me in the single lane at a very high speed. I had to brake to avoid rear-ending them and I must have slid for half the exit lane. Ruined my tires. If you do it, take the time to relearn the driving dynamics, especially if it's a sporty car that you're going to be driving in a sporty manner.
The Following User Says Thank You to Valkyrie5.7 For This Useful Post:
LATECH (04-14-2013)
Old 04-14-2013, 07:21 PM
5.0 5.0 is offline
How exactly did he disable his abs? Did he pull the fuse?
Old 04-14-2013, 07:46 PM
Wiki Edits: 15
Yeah, sorry should have specified.
Old 04-15-2013, 03:12 AM
lstech- how about hitting a concrete pole in home depo parking lot,lol. that's what happened when my abs wouldn't let me stop. turns out, I had a wheel bearing about to come apart.
Old 04-15-2013, 03:16 AM
abs spoils us in our driving habits. if you pull the fuse, you will end up forgetting about it and then hit the brakes real hard because of a tailgater (ask how I know) and almost crash. wont want to do that but once!
302, 5.0, abs, mustang, ring
Replace none abs wheel bearing with abs bearing jrmz28 Hotrodding Basics 5 04-22-2011 07:14 PM
Abs eric kyttle Suspension - Brakes - Steering 1 03-05-2007 03:40 PM
What do I do about the abs? gROCERYgEtteR Suspension - Brakes - Steering 6 09-19-2005 10:29 PM
ABS on non-abs equipped cars; abs kits Fragzem Suspension - Brakes - Steering 0 10-29-2003 01:06 AM
1991 Sonoma ABS Question bluesman123 Suspension - Brakes - Steering 5 05-13-2003 07:34 PM
