Can you cut down a normal wrench or Allen wrench to fit?
I had headers on my '72 w/AC, but mine just had 3/8" or maybe 7/16" hex heads. I had a short (under 4" long) 3/8"x7/16" 12-point box-end wrench that barely fit in that area. I could turn it only one tooth at a time on a couple of them, but it worked for me. Might be worth some frustration to get a used wrench at a pawn shop and hack it up, maybe even heat it up and bend it to suit your needs. |
a/c in nova
I had the same problem in a 67 camaro with factory air. The evaporator coil sits real close to the side of the box. I took a small wrench from an ignition set and had to grind the outside on the hex down to fit because of clearance to the header, then attach a wire to to pull on when the wrench was placed in the correct position. Good luck as you kids will probably learn some new words!
| Header bolt striped | 49dream | Engine | 7 | 04-18-2006 05:18 PM |
| "Bowed" deck lid | cruzinTLT | Body - Exterior | 3 | 03-04-2005 09:24 PM |
| F-body differentials, 9 bolt Borg Warner vs. GM 10 bolt | Mad Maggot | Transmission - Rearend | 8 | 02-17-2005 08:02 PM |
| Header Bolt Questions | Phyrkrakr | Engine | 5 | 07-17-2003 07:32 AM |
| Stripped Header bolt | Sampson | Engine | 7 | 07-12-2003 10:47 PM |
