AC condenser - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-23-2006, 03:18 PM
AC condenser
I am putting a 302 in a 97 ranger with AC. The radiator is larger and the only way I can get the condenser to fit is to "modify" (ie cut the dickens out of the radiator support) or use a smaller condenser ( the Ford Festiva will fit) Would this mess up the AC cooling?
Old 07-23-2006, 03:50 PM
Jmark's Avatar
There are alot of things taken into consideration when the factory designs anything. The size of the compressor and flow needed to cool the vehicle will determine the size of the condensor, along with the airflow that the cooling system will generate. With that said, about all you can do is try the smaller condensor and monitor the A/C pressure readings making sure the high side stays in a resonable range during all driving phases.
Mark
Old 07-23-2006, 05:03 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
You lost me.
If the radiator is larger why would you need to install a smaller condenser than what the factory used?
YES. Smaller condensers reduce cooling capacity significantly.
Use duracool refrigerant www.duracool.com
www.readershotrods.com
Old 07-23-2006, 06:51 PM
The 302 needs a lot more cooling than the 2.3 four banger that was in the Ranger originally. Space is tight. James Duff makes a radiator that tuckes under the radiator support bracket and gives you about 2-3 inches more room. This is where the old condenser sat. To move the condenser forward you either put it in front of the radiator mount bracket with a lot of modification or find a smaller one that will work.
Old 07-23-2006, 07:03 PM
I also apologize for being rude. Thank you all for your help!!! I am really new at building and this is my first project. Seemed simple when I started but got complex in a hurry!!
Old 07-23-2006, 07:13 PM
xntrik's Avatar
Rude, ok, when?
Ah, so thickness is the problem not outside dimensions. OK
Jmark is correct. Too small of a condensor might not be compatible with your compressor. Won't pass enough stuff through it.
Start looking at the condensers in lots of these new cars, some are pretty thin. When you find something that dimensionally will work with less hassle, find a buddy at the local body shop and have him order one for you for say, $ 10 over cost, or find that model in the salvage yard for 1/3 the price. Left or right hose fittings doesn't matter, you can turn it around.
Remember, frontal area is most important, though thickness does count.
Maybe you can mount it flat to the front of the radiator before you install the radiator, almost like a big transmission cooler. But don't use those plastic zip things, make brackets.
If you can get a 5.0 radiator in there, that thing will cool ok with a condensor in front if you use an engine driven fan.
Also Vintage Air in San Antonio has some excellent products. not cheap like the body shop though.
Do NOT buy AC Delco Duraguard Oil Filters!!! indy_85stariones Engine 75 07-06-2009 02:19 AM
crazy ac sheilaay Electrical 1 03-17-2006 11:51 AM
ac to dc amp rating HELP???? Ratchet Electrical 7 01-23-2006 04:53 PM
Converting non-AC to AC Barts71RS General Rodding Tech 2 09-06-2005 09:59 PM
AC regular vs AC platinum vs AC rapidfire plugs ChevelleSS_LS6 Engine 2 10-05-2004 10:00 AM
