AC and crank pulley - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2010, 08:13 AM
AC and crank pulley
I have a 78 Monte Carlo 383 small block daily driver. The AC has been converted to R134. Since then, I have replaced the compressor twice. One mechanic thinks my crank pulley is too big. It's a 3 grove (long neck water pump) 7 and 5/8 inch pulley. I think the original 305 small block is 6.6 inches. Do I have to swap out the pulley? Is anyone running a 383 small block with AC and the larger pulley? Any advice much appreciated.
Old 05-18-2010, 02:51 PM
T-bucket23's Avatar
Wiki Edits: 26
What failed on the compressor and how was it converted.
All rotational parts are designed to work in a certain rpm range. You have changed the rpm range quite a bit with that larger pulley.
I have also seen many r134 conversions done wrong, wrong oil, wrong orifice etc.
Chet
Old 05-18-2010, 04:17 PM
I don't know exactly what elements of the compressor failed except to say that it seized up on the highway with a howl. I pulled over and cut the AC belt off.
4.3 V6 no ps / AC, serp needs idler pulley user151 Engine 2 12-22-2008 06:23 AM
Overheating 350...help! fireman111 Engine 157 03-21-2008 08:54 AM
Pulley Change Out Long to Short Water Pump Mule Engine 7 05-25-2007 07:06 AM
belt slippage on fan pulley? oldguy829 Engine 8 09-23-2006 10:17 AM
