AC delete pulley - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2010, 08:25 AM
6426yy's Avatar
AC delete pulley
I'm wanting to pull the serpentine belt set-up off a '95 chevy truck to put in my old 83. does anyone know where I can get the pulley to remove a AC compressor? Part number would be great.
Old 07-25-2010, 08:39 AM
LATECH's Avatar
GM dealer would be the place or scour the u pullit yard. The factory setup with or without A I R ( not a/c) shows a idler in place of the A/C compressor.
Old 07-25-2010, 09:00 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Can also order this thru an AutoZone dealer.
Motormite part #34152
http://www.autozone.com/autozone/par...mString=search
Old 07-25-2010, 10:52 PM
Should be able to just buy a shorter belt and bypass it that way. But why? Unless the AC is not installed in the truck. But even then you could leave the compressor there and not need a delete pulley. And the AC compressor doesnt take any power to run when its not on. So deleting it doesnt do any good.
Old 07-28-2010, 06:38 AM
6426yy's Avatar
thanks guys, the truck does not have air and I'd like to clean up the engine bay a little. Removing the compressor also removes weight, not that it matters much but everything helps.
AC and crank pulley 78 MC Engine 2 05-18-2010 04:17 PM
ac delete question? Jason7504 Hotrodding Basics 6 05-01-2010 11:01 AM
4.3 V6 no ps / AC, serp needs idler pulley user151 Engine 2 12-22-2008 06:23 AM
90s SBC Power Steering Pump pulley Removal Help Mustangsaly Engine 12 10-08-2006 06:00 PM
Strange pulley issue... Classix_Lover Engine 10 02-12-2006 07:12 PM
