ac/heater blower motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2011, 12:25 AM
hey guys where is the blower motor located on a 85 chevrolet c10. mine hasnt been working the past few years. im gettin it fixed this year so i wont freeze my *** off
Old 11-07-2011, 04:45 AM
The motor is very easy to get to. Its mounted on the passenger side under the hood. If you have A/C there is a large black plenum for the A/C evaporator. Between the plenum and the passenger side fender you will see the tail end of the blower. It has an electrical connector and small vent tube connected to it.
There is also a high speed blower relay and the resistor pack that is used to adjust the speeds. All of them are mounted on the plenum and can be checked out and/or replaced from under the hood. There is also a power lead that runs across the top of the firewall, with a separate fuse. This provides direct 30 amp power to the high speed blower motor relay. On my truck this fuse heated up the fuse holder so much that it melted and came apart. I finally fixed it by switching to a newer style fuse holder and fuse.
Bruce
Help to figure out why heater blower motor wont work eric32 Electrical 5 09-09-2008 05:41 PM
Wiring in Heater Blower 75400truck Electrical 3 12-30-2004 09:17 PM
Wiring in Heater Blower 75400truck Electrical 2 12-29-2004 05:19 PM
Heater Blower inop ArmyofOne Electrical 4 10-17-2002 04:44 AM
Heater Blower MI2600 Electrical 4 09-09-2002 07:34 PM
