Accel breakerless ignition - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2007, 03:32 PM
I have this electronic ignition (non-HEI) that I want to put in my early small block. This car is a cruiser, not a racer. The instructions from Accel specify a coil with less than 1 ohm resistance across the primary windings. All the stock GM coils I have checked are about 1.8 ohms. I'm not worried about the warranty as this dist. has been around for awhile. How critical is this to the life of the dist?
Old 07-21-2007, 04:56 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Most coils , (stock) , read LESS than an OHM, but more than "000" on the primary side...
BE sure all wires are disconnected before testing..this will add resistance.
The added resistance MAY be internal ballast..OR your meter may be out of calibration at R X 1, or the battery's may be low..check that.
As for hurting anything..nope..It may run like crap at top end..under full load..but you , by adding resistance will not burn out a module..
One suggestion, bring your (checked) meter to the auto parts store, and measure the primary on some Non~Stock performance coils..I think you'll find what you want.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Ignition system info................ poncho62 Electrical 18 10-11-2008 10:10 PM
general question abou quality of accel ignition components lowROLLERchevy Engine 25 03-04-2007 08:39 AM
Help me pick- Electronic Ignition Coil Francis Electrical 27 04-24-2006 05:11 AM
Ignition Problem malibuman66 Electrical 17 01-24-2006 01:05 AM
Olds 98 Ignition Module Problems awbazar Electrical 1 01-12-2004 06:42 AM
