Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 05-21-2008, 06:17 AM
red rs ss 68's Avatar
red rs ss 68 red rs ss 68 is offline
no substitute for cubic inchs
accel dizzy vacuum advance set wrong from factory
just installed a new ignition accel dizzy and mallory hyfire box. when i got her running it popped under load until i removed the vacuum advance line then it ran fine i readjusted the advance it seems it was wrong from the start the book says it is set at 12 degrees advance i think it was more like 20 problem now is how do i know what it is set at now. thanks sean
Old 05-21-2008, 06:35 AM
Double_v23's Avatar
Double_v23 Double_v23 is offline
Horsepower Enthusiast
re: accel dizzy vacuum advance set wrong from factory
When you installed the distributor you should have set it to 12 degrees advance by turning the distributor if you adjusted the advance you probably aren't going to get full vacuum advance out of it anymore.
Old 05-21-2008, 06:45 AM
i did set it at 12 but still had the problem also it turned over like it had to much initial when i took the vacuum off it was fine sean
Old 05-21-2008, 06:53 AM
Double_v23's Avatar
Did you have the vacuum advance hose on the ported or unported vaccum off the carb?
Old 05-21-2008, 04:56 PM
T-bucket23's Avatar
T-bucket23 T-bucket23 is offline
Moderator
 T-bucket23's barnstar
There is not enough vacuum on crank to pull the vacuum advance in normally. You should check everything again
Old 05-21-2008, 06:32 PM
hi yeah i know that but seriuosly that is what it was doing it was set up off the port on my 600 dp holley should have been perfect. mind you it goes like hell now it is a 350 sbc edelbrock angle plug rpm heads rpm manifold mr gasket headers flat top pistons turbo 400 2500 stall 3.1 lsd 9 inch all wrapped in camaro shell sounds yum hey sean
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "accel dizzy vacuum advance set wrong from factory"
Do I need vacuum advance? (Long Post) Chevy21 Engine 49 10-25-2007 12:51 PM
ign. timing? runn141 Engine 15 02-18-2007 08:21 AM
Cam lope question joeford Engine 4 08-10-2006 08:14 AM
283 vacuum advance nickeldimerods Engine 3 01-14-2006 05:13 PM
where is the best place to hook up the vacuum advance? Mad Maggot Engine 7 06-17-2005 06:01 PM
