accel points eliminator? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2006, 10:19 AM
byrdta76's Avatar
I am running points on my camaro. I ran across a points eliminator by accel the other day. How does it work and is it hard to install? Do I do away with my cap and rotor or does that stay the same?
Old 07-06-2006, 10:27 AM
sbchevfreak's Avatar
Licenced Automotive Technician
The general consensus is that Accel products are kinda crappy. If it were mine, Id use a Pertronix kit, as they make a good product. They are very easy to install, just follow the directions.
Old 07-06-2006, 10:46 AM
cabowabo's Avatar
big Q
use a msd box
if you get the msd box 6 a those points would work great
Old 07-06-2006, 10:55 AM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
I agree with sbchevfreak go with the Pertronix kit I have installed 2 in the last 3 weeks and they have worked out great. Just my .02
Steve
Old 07-06-2006, 12:35 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
There has been a lot of bad stuff on this site about pertronics going bad.
If your distributor is NOT worn and you don't need more than 5000 rpm reliably, then a points distributor might be OK.
Points always have a lot of spark scatter and irregular timing when the plates and shaft move around. Variations of 3* are common on new distributors.
Go full electronic if possible, I like MSD.
Old 07-06-2006, 02:27 PM
Wiki Edits: 31
Crane and Mallory both have there own magnetic pickups that replace points for the SBC. I'v heard good and bad about petronix ign components, sometimes there the only way to get rid of points ( ex, most rare/ uncommon engines, and 6cyl's ) and I'v heard if there installed wrong they will work for a short time then burn up, don't know the truth as I have never installed 1 ( Ignitor ), I may install 1 on my '67 200 6 Falcon, and get rid of the points.
Old 07-06-2006, 05:19 PM
You still need the ballast wire and a stock voltage coil with the eliminator kits, as HEI coils will burn the eliminators up.
Old 07-06-2006, 10:16 PM
Glennk's Avatar
pertronix
Thats exactly why they burn up. People think they can just get rid of the ballast resister and go..Not so..You need it.........I have one in my coupe and 0 problems in 2 yrs. GlennK
Points and Condensor problems oldschoolrods Electrical 14 10-15-2004 12:52 PM
Points System with a new Accel 12 volt universal coil?? 61ChevyTruck Hotrodding Basics 1 10-06-2004 12:59 PM
points pointer danekejt Engine 6 08-25-2003 06:42 AM
Points distributor Camaro2Fast4u Engine 2 02-24-2003 04:48 AM
C-4 shift points 5.0 Fury Transmission - Rearend 1 07-30-2002 11:48 AM
