Acceptable Piston Damage? possibly dropped...? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2010, 09:19 PM
I have read countless posts on this forum and respect its members opinions very much and now I have a question and really look foward to hearing from yall.
I just got my engine back from the machine shop. I gave them my pistons to balance the rotating assembly aswell as press on the con rods. Either one piston was dropped at the shop or shipped damaged (I don't care to speculate). I can see that when it landed on its side, it pressed up on the top/deck side of the piston. I did my best to get a focused picture (not easy). The owner of the machine shop took a file to it and mostly evened it out but this is what it still looks like.
What do you guys think? Thanks so much.
ID:	50061   Click image for larger version
ID:	50062   Click image for larger version
Old 11-16-2010, 09:43 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I don't think it's as bad as it looks in the pictures. A purist would say nay, I think you're OK to polish it up and use it.
Old 11-16-2010, 09:48 PM
ericnova72's Avatar
More for Less Racer
Unfortunate that it happened, but on the good side it doesn't really hurt anything, it is fine to use. A plus is that it is on the pin axis side, and not 90 to the pin which would put it on a thrust side.
Use it without worry.
Old 11-16-2010, 10:36 PM
Last journal entry: headers
yup i agree run it. it will be fine
Old 11-16-2010, 11:08 PM
thanks guys for the quick responses
Blower motor blowby and piston damage 68NovaSS Engine 15 08-27-2009 06:40 AM
terrible driveability, tuning problem klr650 Engine 28 02-21-2009 12:06 PM
Piston Skirt Damage: Consequences? Petea216 Engine 14 04-20-2007 04:48 PM
Intresting, maybe, new cars with the same exact damage......... MARTINSR Off-Topic 0 12-30-2006 01:20 PM
302 piston dim. compared to 327 piston Dave Y. Engine 2 09-25-2002 08:55 AM
