Accessory bracket trouble...need help asap - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2008, 08:29 AM
I replaced the water pump on my Lesabre which currently has a pontiac 301 in it right now. When i replaced it i had to take off a bracket for my alternator and my powersteering pump. Now i have the new pump put on the i cant figure out how the bracket i took off goes on. This is probably one of the goofiest accessory belt drive setups i've ever seen and i was wondering if any of you have any advice. i have a general idea how the bracket sits on there but i cant figure out how the powersteering pump bolted on to the same bracket. i'll post pics later of the bracket and where i think the bracket bolts and see if that helps any. Any help would be appreciated. Thanks.
Old 10-09-2008, 08:39 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Some pictures would definately help.
Accessory hole screw up justdig Engine 2 09-24-2008 08:12 PM
Cycle fender bracket suggestions cboy General Rodding Tech 5 10-21-2007 08:46 AM
'70 Chevelle throttle bracket ? TailGater Engine 6 05-24-2006 03:54 PM
Moroso Throttle cable Bracket skeeveman Engine 2 02-14-2005 07:27 AM
q jets for B/O/P and caddy throttle bracket COCHEV Engine 2 07-15-2003 07:36 PM
