accessory holes on the driver or passenger side? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2008, 09:07 PM
*** Please post solutions ***
Mounting some 882's 1 end has 1 hole and one has 3... will be running alternator and power steering only...
which side should I put the holes?
Old 11-29-2008, 10:08 PM
DoubleVision's Avatar
3 holes goes on the drivers side. 1 hole goes on the passengers side.
Old 11-29-2008, 10:24 PM
Thanx that's whay I thought
Old 11-30-2008, 07:50 AM
it will always be that way , what you need to know is what side the temp sensor you want it to go on .
them plugs are hard as heii to remove , so if you have a open outlet , put it where you need it .
them bolt holes are the same on each head .
driver side drum smoking hot. pi71 Suspension - Brakes - Steering 4 10-13-2008 07:22 PM
390 smoking on driver side old fords Engine 4 09-14-2008 08:36 PM
head accessory holes hot57 Engine 12 07-08-2003 05:29 PM
can i drill accessory holes striker86 Engine 4 05-25-2003 12:24 PM
Filling up holes in body, including rust holes Mr.56Chevy Body - Exterior 5 12-12-2002 11:55 AM
