-   -   accessory lights dim when head lights turned on (http://www.hotrodders.com/forum/accessory-lights-dim-when-head-lights-turned-193355.html)
36int 02-25-2011 02:01 PM
hi, I have a 1993 Jeep Grand Cherokee limited. I never noticed it before, but now in the day time its real obvious. But when I turn on my headlights, all the accessory lights such as the overhead compass and the iinfo console, go dim. Its so dim that in daylight you can't see them at all.
I had this happen on a chevy astro van I had before, never did know what caused it. Any suggestions. The lights that go dim are all led's I believe. Doesn't seem to affect the lights on my aftermarket radio.
Jeff
matt167 02-25-2011 02:12 PM
turn the dimmer up. should be a dial right next to the light switch, or if an old pull type, the knob rotates
eloc431962 02-25-2011 02:15 PM
Sounds like it could be a voltage problem JMO Have you check that yet ?
Although i have seen some newer rides that the dash light will dim when the headlights are on as a safety thing i guess but i can't remember the year vehicle it was.
Cole
eloc431962 02-25-2011 02:17 PM
HaHaHa!!!!!!!!!!!!!!!! Forgot about that one matt. You go to turn on the lights and accidentally turn the knob when pulling it out and light's went out/dim.
Cole
75gmck25 02-25-2011 03:45 PM
Having the dash lights dim with the headlights on is normal on most new cars. However, on my last Dodge you could turn the dimmer all the way up (or down?) and there was a click just after full range where it would set them to stay bright at all times, even when the headlights were on. It was documented in the owner's manual.
Bruce
36int 03-02-2011 08:41 PM
not dimmer
its not the dimmer, that is up all the way. what is JMO
EOD Guy 03-03-2011 03:53 AM
It's "Just My Opinion" same as "IMO" In My Opinion
cobalt327 03-03-2011 04:31 AM
My '95 GC does the same thing, it's normal for them. :rolleyes:
If that's ALL the complaints you have regarding the electrical system/dash display consider yourself darned lucky- those Jeeps have the most problems of any vehicle I have ever heard of- including ones w/Lucas electronics! :smash:
hduff 04-10-2011 11:59 AM
It's a poor ground somewhere, a dirty dimmer or corroded bulb sockets or a loose wire.
No fun to troubleshoot.
