accessory lights dim when head lights turned on - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2011, 02:01 PM
hi, I have a 1993 Jeep Grand Cherokee limited. I never noticed it before, but now in the day time its real obvious. But when I turn on my headlights, all the accessory lights such as the overhead compass and the iinfo console, go dim. Its so dim that in daylight you can't see them at all.
I had this happen on a chevy astro van I had before, never did know what caused it. Any suggestions. The lights that go dim are all led's I believe. Doesn't seem to affect the lights on my aftermarket radio.
Jeff
Old 02-25-2011, 02:12 PM
Wiki Edits: 31
turn the dimmer up. should be a dial right next to the light switch, or if an old pull type, the knob rotates
Old 02-25-2011, 02:15 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Sounds like it could be a voltage problem JMO Have you check that yet ?
Although i have seen some newer rides that the dash light will dim when the headlights are on as a safety thing i guess but i can't remember the year vehicle it was.
Cole
Old 02-25-2011, 02:17 PM
eloc431962's Avatar
Wiki Edits: 37
HaHaHa!!!!!!!!!!!!!!!! Forgot about that one matt. You go to turn on the lights and accidentally turn the knob when pulling it out and light's went out/dim.
Cole
Old 02-25-2011, 03:45 PM
75gmck25's Avatar
Having the dash lights dim with the headlights on is normal on most new cars. However, on my last Dodge you could turn the dimmer all the way up (or down?) and there was a click just after full range where it would set them to stay bright at all times, even when the headlights were on. It was documented in the owner's manual.
Bruce
Old 03-02-2011, 08:41 PM
not dimmer
its not the dimmer, that is up all the way. what is JMO
Old 03-03-2011, 03:53 AM
EOD Guy's Avatar
It's "Just My Opinion" same as "IMO" In My Opinion
Old 03-03-2011, 04:31 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
My '95 GC does the same thing, it's normal for them.
If that's ALL the complaints you have regarding the electrical system/dash display consider yourself darned lucky- those Jeeps have the most problems of any vehicle I have ever heard of- including ones w/Lucas electronics!
Old 04-10-2011, 11:59 AM
hduff's Avatar
Fix it until it breaks
Last journal entry: Clutter
It's a poor ground somewhere, a dirty dimmer or corroded bulb sockets or a loose wire.
No fun to troubleshoot.
tail lights and dash lights quit ashman Electrical 5 08-30-2010 12:27 AM
79 TA: dash lights and tail lights fuse keeps blowing Gladis Electrical 6 12-01-2007 12:43 AM
Parking lights from Turn signal lights 32chevy vett Electrical 7 03-30-2007 06:46 AM
voltage to tail lights vs brake lights? stratt134 Electrical 12 06-10-2006 06:51 PM
Brake lights, head lights 40chevy Electrical 9 05-03-2006 08:59 AM
