Acetone or Alchol Instead of Wax/Grease Remover? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2007, 04:17 PM
SHIFTY101EASY's Avatar
Last journal entry: Stripping Paint + Buying New Metal
can you use either one instead? i went to napa and kragen....the guys at kragen could have figured i was speaking greek when i said "wax and grease remover" and i scoured the shelves...definitely didnt have any. the guys at napa said they didnt have any but they "always just use some acetone or alcohol"...seem sorta sketchy to me...
i went to home depot and lowes and they had some stuff like acetone and alcohol and stuff but they also had some degreasers and wax removers and stuff but they reminded me more of like kitchen products than for use cleaning a car so i didnt get those either....would any of those work or should i just order some up?
Old 06-17-2007, 05:13 PM
Tell me what it is your trying to clean. If it's paint related, I can make some suggestions in the right directions. ROCKETMAN
Old 06-17-2007, 05:29 PM
final prep before spraying primer and paint.
Old 06-17-2007, 06:35 PM
NO, do NOT use acetone or alcohol, use the proper products. Acetone is very heavy and can take soak into your substrate, alcohol is too fast and flashes off before you have removed the contaminant. Now, yes, there is alcohol and acetone in some wax and grease removers. But it is blended, AND it is of higher quality.
Read the following basics on wax and grease remover. In it you will find part numbers that your NAPA store can order for you. Your NAPA store isn't a paint mixing store I quess. NAPA has a full paint line called Martin Senour. Even though your store doesn't know much about the products there are some simple primers, solvents, clears and the like that you could be getting thru them if you wanted. Now, it is much better to be buying your products from someone who knows what they are doing. But if you are in a bind you could get it there.
The products listed in the article are ordered by the NAPA store by adding a GAL for gallon in front of the number. They are in the "MS" line (tell them this if they don't know) So you order in the MS line and put the GAL then the number and they can get you any one of them in a day or so.
Click here for the "Basics of Basics" to Wax and grease removers.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Glass cleaner after wax and grease remover? wreckedGTI Body - Exterior 20 06-17-2007 05:21 PM
Naptha and Acetone ChevelleSS_LS6 Hotrodding Basics 9 09-04-2006 02:52 PM
My Acetone Testing Results Ghetto Jet Engine 32 11-18-2005 09:32 PM
Acetone Claimed to Improve Fuel Efficiency... awbazar Engine 13 10-30-2005 05:47 AM
acetone in gas mb42588 Introduce Yourself 1 10-06-2005 06:46 AM
