Achieving Proper Rocker Arm Geometry
I have been following this Comp Cams video regarding rocker arm geometry.
http://www.youtube.com/watch?v=Cqx8C...eature=related Differences between my setup and the video are; I am using stock stamped rockers with ball pivot and hydralic lifters (filled with oil). Lifter is on base cirlcle. Is the video procedure valid with my setup or should I be doing something different? My valve stem wear bands are too low on the valve stem so I am lengthening the adjustable push rod to move the band up toward intake manifold. Note in the video they adjust the push rod length with out a poly lock. I tried this but couldn't get the band to move up by lengthening the push rod. Here is what I am going to try next does this sound right? Set the adjustable able push rod to stock length 9.125". Mark the valve stem with a marker. Install rocker arm and tighten down poly lock until slight resistance is felt when rotating the adjustable push rod (zero lash). Lengthen the adjustable push rod until the rocker arm tip (center of contact area) is just inboard (toward intake) center of valve stem. Then give poly lock half a turn and screw down set screw. Spin engine over a few times. Remove rocker arm and note position of wear band on valve stem. Adjust push rod length & repeat as necessary. BT |
If your wear pattern it very far from center you either need new rockers or to move the rocker stud location. BTW, on stud mount rocker arms you very rarely see a pattern that is perfectly centered, just focus on minimizing the pattern rather than getting it perfectly centered. |
ScojoDak, you are the one who has it wrong
, you are simply regurgitating the same incorrect method that Comp Cams and others still have up on their web site. Never was the correct method.AP72's advice is actually the correct method. Search "Miller Mid-Lift" here and around the web for the only truly correct valvetrain geometry info and how-to. The info on Comp's site, and the referenced video couldn't be more wrong. Just as Jesel, T&D, and the older Lunati catalog...along with pro engine builders. Last edited by ericnova72; 11-02-2011 at 12:35 PM. |
Its amazing how something so simple could be so messed up, if you draw out the geometry in an exaggerated fashion its pretty easily apparent. |
The video is dead on! Been doing it this way for thirty years the only difference in what I used to do and what they are doing is that I have yet to try the newer adjustable pushrods. For years I would use different length tubes and it was a pain in the *****. I would wind up with some times as many six different length tubes in the same engine. Just like the video says "you gotta keep as much of that wear pattern on the center of the valve stem as you can get.
Valve geometry
Comp cams info is old tech. It is wasted motion across the tip of the valve stem. Millers mid lift is the correct way to set up valve geometry. It can easly be achieved by changing rocker stud lengths and or rocker arms. I went through this on a 500ci bbc w/ dart pro 1 heads. My contact patterns were not centered(exactly) but the contact patches on the tips were .030 wide through the full lift of the valve, which gave me the least amount of wasted motion. There is absolutly no scrubbing of the roller across the tip of the valve w/ mid lift geometry.
I'm far from an expert on this...The mid lift theory....Smokey Yunick discussed this subject 30 years ago in one of his technical books.
Not a Chevy V-8 but on a vintage performance GMC inline 6. I had rocker geometry issues from changes in the valve stem height ,block and head milling.I spent some time with the engine mocked up cycling the valve train and "adjusting" the rocker geometry so the rocker went the same distance under center during lash and over center during full lift.And also keep the rocker contact near the center of the valve stem. This made sense to me from a mechanical viewpoint......I assume this is what's being talked about? |
| achieving zero deck | 1975yellowC3 | Engine | 3 | 11-29-2010 09:14 PM |
| proper cam break in and rocker adjustment | untchable502 | Engine | 6 | 03-02-2008 05:48 PM |
| rocker arm & valve tip geometry | ljjjrome | Engine | 2 | 06-16-2007 10:21 PM |
| SBC Rocker Arm Geometry | radracer43 | Engine | 7 | 07-16-2005 10:44 AM |
| 1.65 sbc rocker geometry question???? | btp76 | Engine | 8 | 02-15-2005 10:38 PM |
