Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - acid base primer
Old 03-15-2013, 08:04 PM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
It is possible to repair it so that you don't have this problem again...first of all exactly where is it blistering? Is it about half way up the sail panel where the roof would be joined by the quarter, and I take it it's happening on both sides...Do you know what products where used the last time you had it repaired? Sometimes if the wrong product is used on a factory joint where they used a led filler, problems like your experiencing can arise...If you had pictures that would help as well. Let me know and I'll try and help with proper products and procedures so that you can put this issue to bed and enjoy the car.
Ray
