Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - acid base primer
Old 03-15-2013, 10:12 PM
carolinacustoms's Avatar
carolinacustoms carolinacustoms is offline
Automotive Extraordinaire
Just another thought, If it is on the factory seam, it could be rust under the lead causing your problem. If the last time it was "fixed", it was simply sanded smooth and repainted then the lead will continue to bubble until the underlying rust is fixed. Again pictures and products used would greatly help.
Kelly
