Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - acid base primer
Old 03-15-2013, 10:24 PM
MARTINSR MARTINSR is offline
Yep, any way you look at it, sand it down to the metal and get rid of all the junk that could be there. When you hit the lead look at the edges where it hits the metal, how does it look? If you apply some epoxy primer over it you will likely solve it but you may need to remove that lead and start from scratch.
