Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - acid base primer
Old 03-15-2013, 10:34 PM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
Thanks Kelly, that's exactly where I was going...that lead has been in there for over 40 years almost 50 years and it is the first place to look. I agree with you as well Brian, it's got to go down to bare metal and it should be taken down one layer at a time to see exactly where things are going wrong. All it take is a pin hole in the lead filler to cause blistering and unless it's taken out and repaired properly it will come back and get worse every time. It could have happened the first time it was painted, if it's down to bare metal and a little moisture gets in an area where the lead has been disturbed it will stat to rust from underneath.
Ray
