Ackerman with front mounted rack - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-03-2009, 12:23 PM
Last journal entry: Latest picture
I'm designing a small off-road buggy and can't seem to figure out how to measure the ackerman when the rack is mounted if front of the front wheel centerline.
All the sites I've been on, only show examples of the rack mounted rear ward of the wheel centerline.
Thanks for any help or links. Dan
www.****************.com
Last edited by cboy; 02-15-2010 at 08:23 AM. Reason: Advertising. Please see: commercial posting guidelines.
Old 08-03-2009, 06:24 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
A close approximation would be to project a line originating from the center of the tie rod hole on the steering arm, past the centerline of the lower ball joint toward the rear. If when doing this on both sides the lines meet at or near the center of the rear axle you are in the ballpark. This technique does not factor in the caster or king pin inclination angle in the front end, but you will know if you are on the right track.
Andy
Looking for a 22 1/2 center to center power rack and pinion grobb284 Suspension - Brakes - Steering 5 09-28-2008 06:26 AM
1931/32 chevy 1.5 ton what front clip to use on it?? Riley Suspension - Brakes - Steering 4 09-22-2008 01:17 PM
GM Front Diff. Reliability For Full Time Use. M&M CUSTOM Transmission - Rearend 4 10-31-2003 05:36 PM
Hotrodders Knowledge Cluster: Front Clip Installs/Subframes/Frame Swaps Jon Suspension - Brakes - Steering 0 10-12-2003 03:56 PM
staight axle interchange 27trackt Suspension - Brakes - Steering 3 09-02-2003 10:12 PM
