Acklands alkyd enamel - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2009, 01:01 PM
Hi im starting to get down to paint on my stepside. I was goin to go with some aklyd enamel from acklands grainger it shows to use with an epoxy primer i think. Just wondering any thoughts/ comments this wil be my first paint so i want every thing to work right. Thanks,Jake
Old 05-28-2009, 09:48 PM
Skip the Acklands enamel.
Go to Micron Coatings on Sheppard st in Winnipeg, www.microncoatings.ca. Look under product data for mc 200 clear baseThey have a great Industrial high gloss enamel, they can mix any color, MC 200, around $45.00 a gallon.
Go with an epoxy primer first, then a 2 k urethane primer/surfacer, from Rondex, PF 656, $65.00 a gallon, then block,wetsand, and then shoot on your enamel.
here are some pics I have just shot this paint on my car, about 2 days ago.
Name:	2nd paint (1).JPG
ID:	38449   Click image for larger version
Name:	2nd paint (2).JPG
Old 05-29-2009, 05:53 PM
Well im not trying to do anything to serious just getting the truck on the road and looking half decent plus this paint is only 27.00$ a gallon, so im just wondering if it'll work out ok?
Old 05-29-2009, 05:58 PM
Wiki Edits: 31
it'll fade out and chalk up quick
Old 05-29-2009, 10:37 PM
Okay, then I will use it as a chalk board, thanx for the heads up.......LOL
Alkyd enamel dubie Body - Exterior 17 11-10-2015 05:50 PM
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 04:07 AM
What is Valspar LIC-40 polyurethane enamel? F&J Body - Exterior 1 04-05-2007 12:46 PM
acrylic enamel vs synthetic enamel? yragat Body - Exterior 3 03-30-2007 09:48 PM
acrylic enamel base then acrylic enamel cc swoodard23 Body - Exterior 12 07-30-2005 07:19 PM
