Acrylic Enamel - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 03-30-2007, 03:43 PM
Acrylic Enamel
I've been reading posts about Acrylic Enamel vs. bc/cc and some poor guy is getting the run around. One good thing to remember is that if you use acrylic enamel what you spray is what you get, period. There is no sanding out nibs with 1200/wet, if you do you will ruin the finish. Acrylic enamel oxidizes during the gas-off period and creates the gloss finish. If a hardener is used it will appear 'dry' but 30-days are generally the dry time for cure. And 90 days before any polish. I just sprayed my 1970 Falcon with acrylic enamel and I've got the drips on my shoes to prove it....
Be good to yourself and get the book 'How to paint your car'
-tzrecordz
Old 03-30-2007, 04:39 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Welcome to Hotrodders...this is the Introduction forum...your post about painting needs to be in the Body/Exterior forum.
Old 03-30-2007, 04:49 PM
Wrong area
oops, thank you
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 03:07 AM
Base coat/clear coat urethane over acrylic enamel mervhudson Body - Exterior 5 04-23-2011 10:56 AM
Synthetic Enamel & Acrylic gilby246 Body - Exterior 7 12-29-2005 08:54 PM
acrylic enamel vrs urethane americanLT1 Body - Exterior 4 09-15-2005 10:23 AM
acrylic enamel base then acrylic enamel cc swoodard23 Body - Exterior 12 07-30-2005 06:19 PM
