Acrylic Enamel & Hardner - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2006, 05:09 PM
New Member
Last week I clear coated a motorcycle tank with Acrylic Enamel with the hardner, I mixed too much and still have some left over in a sealed can, my question is I going to clear coat it again tomorrow, can I still use it or should I mix up a fresh batch? thanks Dennis
Old 07-12-2006, 05:58 PM
Wiki Edits: 31
the hardener will cause the paint to gel up, I doubt it will make it until tomorrow.
Old 07-12-2006, 06:02 PM
New Member
thanks, I'll mix up some more--Dennis
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 03:07 AM
Base coat/clear coat urethane over acrylic enamel mervhudson Body - Exterior 5 04-23-2011 10:56 AM
Synthetic Enamel & Acrylic gilby246 Body - Exterior 7 12-29-2005 08:54 PM
acrylic enamel vrs urethane americanLT1 Body - Exterior 4 09-15-2005 10:23 AM
acrylic enamel base then acrylic enamel cc swoodard23 Body - Exterior 12 07-30-2005 06:19 PM
