acrylic enamel help - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2010, 06:18 PM
acrylic enamel help
Does anyone know if there is a good adhesion promoter for single stage acrylic enamel? I got my hands on some single stage, and would like to paint all the plastic on my chevy avalanche. I have years of experience with lacquers, I have always used Bulldog, and have never had chips or peeling not even on bumpers, it always sticks to plastic, I never use a primer with plastic just adhesion promoter and it has never failed, but I read on the bulldog website that it is not compatible with enamels. I usually buy bulldog by the gallon and spray it with my gun. This is going to be my first time to use an enamel paint and I really want it to stick to the plastic, Thanks for any tips or advice...
Old 09-22-2010, 10:41 PM
crashtech's Avatar
Technician
Last wiki edit: Epoxy primer
Wiki Edits: 17
I think they are talking about stirring it into the enamel, if you are using it in the conventional way, it should work. Not only that, I think they may be talking about a different kind of enamel, like old synthetics. Why don't you find something to use as a test panel, spray a little and see how it goes. Do you have a small can of hardener for the AE? It will work much better with it.
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 04:07 AM
Clear urethane over acrylic enamel? Kawdennis Body - Exterior 3 05-07-2007 03:46 PM
Acrylic Enamel tzrecordz Body - Exterior 0 03-30-2007 05:51 PM
Acrylic Enamel tzrecordz Introduce Yourself 2 03-30-2007 05:49 PM
acrylic enamel base then acrylic enamel cc swoodard23 Body - Exterior 12 07-30-2005 07:19 PM
