-   -   Acrylic enamel reducer (http://www.hotrodders.com/forum/acrylic-enamel-reducer-186834.html)
mitmaks 10-30-2010 02:22 PM
What's the best reducer to use with acrylic enamel?
At work we use acetone/toluene/xylene blend but would it be best to use urethane reducer?
jcclark 10-30-2010 05:31 PM
Yes, enamel reducer or urethane reducer will work fine.
You can use either in enamel.
But not the other way around, don't use enamel
reducer in urethane. :pimp:
Runnin'OnEmpty 10-30-2010 10:11 PM
I'd use reducer formulated specificly for acrylic enamel.
It's a mixture of toluene, naptha, acetone, and a couple
of other ingredients.
That blend you already use is probably pretty close....
