Acrylic gas tank - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2011, 09:46 AM
Acrylic gas tank
I just painted my motorcycle with acrylic paint. Put on a couple of coats waited for the paint to harden (i did use hardener) then I wet sanded it. After I wet sanded I was talking to a painter he said I didn't need to wet sand because the clearcoat was mixed in. Anyway so I sprayed it one more time waited for it to dry. I started to buff it and came out dull. Not sure what to do fro here I don't want o spray again. Anyone have any ideas?
Old 04-16-2011, 10:17 AM
When you say acrylic, I assume you mean acrylic enamel with
hardener added? My guess is that the paint wasn't fully cured
when you started buffing and is still soft.
Even with hardener, acrylic enamel dosen't cure as fast as
the urethanes. Try waiting a week or two and buff it again;
the gloss should come back.
Old 04-16-2011, 10:26 AM
Ok I'll try that, thanks. I did wait about 4 days parts were inside. I'll wait anothe week. what type of pad should I use.
Mixing Acrylic Lacquer with Acrylic Urethane waterdude Body - Exterior 23 02-16-2011 09:00 PM
2 Pac over Acrylic fordfuntastic Body - Exterior 1 09-01-2007 07:22 AM
acrylic enamel base then acrylic enamel cc swoodard23 Body - Exterior 12 07-30-2005 07:19 PM
acrylic rdzat Body - Exterior 1 11-19-2002 03:20 PM
Need Tank Sender for Custom Gas Tank.... bg Engine 3 11-05-2002 06:13 PM
