acrylic lacquer vs clear coat - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2010, 02:59 PM
I find the acrylic lacquer much easier to contend with than clear, but clear buffs out nicer, can I shoot clear over the acrylic, why does my acrylic cause the paint to wrinkle (only in very, very small areas, quite anoying really on an otherwise primo job.)
Old 11-09-2010, 05:03 PM
Rag top bird's Avatar
Hot rods are still the king
The best I can remember lacquer base and lacquer clear are about the same it has been 20 years since I have used lacquer but as far as wrinkling goes if you are using a cheap thinner that is hot will cause a problem always use a good thinner
Old 11-11-2010, 08:41 AM
deadbodyman's Avatar
Wiki Edits: 11
Using a urathane clear over lacquer will cause all sorts of problems ...same with uarthane primers over lacquer primers ....the catalized materials will seal in the solvents of the lacquer ,trapping them ...I dont of anyone that uses lacquers anymore...
Old 11-17-2010, 09:08 PM
RAYFIN's Avatar
Last journal entry: before picture
My body man told me he couldn't even BUY lacquer products any more. I know the poly basecoat clearcoat stuff sprays really nice because I did a car with it a few years back. They are using WATER based now, with a poly (I think) clearcoat. A body man told me the equipment is expensive.
Old 11-18-2010, 12:29 PM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
It's getting real hard to find a lacquer thinner high enough quality
to spray lacquers with. I spray my furniture & woodwoorking projects
with lacquer and now only use urethane reducer to thin it down.
I was told to use that by a guy that knows paint chemistry real well
and sure enough it works much better.
I did some lacquer touch-up work on a show car that was lacquer
and the customer supplied the color and clear in lacquer, he got
it at PPG. I thinned it with urethane reducer and it worked great.
It's all I'll use now for lacquer.
Not enough clear coat? nickt93 Body - Exterior 8 05-07-2010 02:28 PM
need help with clear coat & single-stage JR805Ca Body - Exterior 3 03-08-2010 11:40 AM
Clear coat delaminating, can I stop it? Jeepster Body - Exterior 4 07-07-2006 05:50 AM
lacquer clear paint sb454chevy Body - Exterior 3 06-09-2006 09:45 PM
clear coat compatability 2cati Body - Exterior 2 09-17-2002 06:25 PM
