acrylic panels for door? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2011, 09:00 PM
RHOPPER's Avatar
At the upholstery supply shop this weekend, got all my vinyl, chip board, etc. They didn't have any foam board. They recommended a 4x8 black sheet of acrylic instead. They claim it will heat bend just fine and would make good door panels. $40 a sheet is what they sell it for, less 30% for the sale they're having. I haven't found anyone locally who stocks foam board and I was going to just get luan plywood, but I've got a section of cab in my 48 F1 pickup that needs a pretty good bend. Any thoughts on the acrylic sheet, or do I need to continue the hunt for foam board?
Old 10-25-2011, 09:51 AM
I've bent smaller acylic sheets just using a heat gun. It might be a trick on something that big but if it can be done on smaller areas, should be OK.
Old 10-25-2011, 11:19 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Acrylic would work, but it is heavier and forms at 350 degrees. PVC foamboard is a far better choice and forms at a much lower temperature. The price is good, I pay $28 for a sheet of foamboard, which is what your cost would be on the acrylic.
How about A&C Plastic products, and Colorado Plastic Products, both in Colorado Springs?
Door Panels redvassilis Interior 1 03-31-2010 10:01 AM
How do you layer panels on door panels genr8rs Interior 6 04-05-2006 07:24 PM
door panels cgreene Interior 1 05-07-2003 07:15 PM
Door Panels Chevelle Crazy Interior 10 02-10-2003 04:31 PM
3D door panels 74-Roadster Interior 6 02-01-2003 06:17 PM
