Active 9-inch rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2008, 11:55 PM
1300
Hey guys, what are you think about idea to fabricate active differential out of old nine-incher (or 10-bolt or wherever you want)?
Old 02-19-2008, 12:44 AM
powerrodsmike's Avatar
Wiki Edits: 161
When you say "active" do you mean independant?
check this thread.
IRS kits, C4 'vette, Heidts, or Kugel????
Later, mikey
BE different....ACT normal.
Old 02-19-2008, 06:28 AM
31 five window
Last journal entry: grill and rear end
Mikey,I was trying to figure that one out too. But I think you got it.
Old 02-22-2008, 06:41 AM
1300
Guys, you really don't know about active diffs? Good morning!
from Wikipedia:
Active differentials
A relatively new technology is the electronically-controlled active differential. A computer uses inputs from multiple sensors, including yaw rate, steering angle, and lateral acceleration and adjusts the distribution of torque to compensate for undesirable handling behaviors like understeer. Active differentials used to play a large role in the World Rally Championship, but in the 2006 season the FIA has limited the use of active differentials only to those drivers who have not competed in the World Rally Championship in the last five years.
Fully integrated active differentials are used on the Ferrari F430 and on the rear wheels in the Acura RL.
The second constraint of the differential is passive – it is actuated by the friction kinematics chain through the ground. The difference in torque on the tires (caused by turns or bumpy ground) drives the second degree of freedom, (overcoming the torque of inner friction) to equalise the driving torque on the tires. The sensitivity of the differential depends on the inner friction through the second degree of freedom. All of the differentials (so called “active” and “passive”) use clutches and brakes for restricting the second degree of freedom, so all suffer from the same disadvantage – decreased sensitivity to a dynamically changing environment. The sensitivity of the computer controlled differential is also limited by the time delay caused by sensors and the response time of the actuators.
Have a good reading!
Old 02-22-2008, 08:34 AM
Wiki Edits: 161
I've read enough, you can have them. You can have all the rest of that drive by wire, computer controlled braking and traction control crap. If you want to give up control of your car, ride a bus.
As it seems that the passage you posted implies that the technology has become useless and undesirable in the races that they used to be utilized in as well, except for people who are not good drivers..
Good Morning, indeed.
(you could have just pasted 1 paragraph and linked to the wiki article)
Later, mikey
Old 02-22-2008, 11:23 AM
Countilaw's Avatar
Cox Custom Cars
Boy, Don't I feel stupid now!!!
Sounds like just something else to go wrong.
Frank
Old 02-23-2008, 03:42 AM
1300
Later, mikey
You think? have you ever heard about Nissan Skyline GTR and its race performance?
Old 02-23-2008, 06:44 AM
Wiki Edits: 161
No.
I don't even look at those cars.
I like old American cars.
Without computer controlled driving aids.
When you give up control to a computer, you are no longer the driver. The computer is. I guess it's a matter of pride.
Later, Mikey
Old 02-23-2008, 07:57 AM
leldai73's Avatar
Its just metal,you're the boss
sounds expensive...and complicated, not just buying a used car expensive and complicated. millions of dollars and a team of engineers expensive complicated. so, take pictures.
Old 02-25-2008, 06:12 AM
1300
No.
Well, driving aids question is pretty arguable, but such "i don't even look" philosophy must be named "automotive nacionalism".... cause is just stupid too.
Now you can ban me for "offence on moderator"...
Old 02-25-2008, 06:35 AM
Stovebolter's Avatar
36 Chevy Low Cab
Last journal entry: C4 IRS
I definitely wouldnt concider myself a professional driver by any means. But...I have driven both the EVO and the STI with the active system. I truely didnt like it. As if we don't have enough to keep up with on our nations highways....driving, eating, sending text, talking to the wife, and checking our gps...all the while.....taking out Granny Gilmore's rose bush while gliding around a curve at mach speed. LOL's. I'm just picking on you man!
Dave
Old 02-25-2008, 06:36 AM
I suspect that this question would have gotten better response on a Rally related website somewhere. We're just a bunch of grizzly ol' hotrodders. Hence the name.....
Cam
Old 02-25-2008, 07:36 AM
Wiki Edits: 161
You can believe my lack of interest in new tuner cars is some type of bigotry, but it isn't.
I just have no interest in computer controlled cars.
I answered your initial question because I thought you were asking about something that did interest me, and I could help with. I assumed that you were calling an independent rear end "active". My mistake.
As far as being stupid, ...well, someday I hope to be as smart as you think you are right now.
Have fun dreaming.
Mikey
Old 02-25-2008, 11:23 AM
Minace21's Avatar
im gonna have to go with power on this one and im a younger guy to and i hate imports
Old 02-27-2008, 02:36 AM
1300
Mikey
well, maybe it's my mistake, when I decide, that active diff subject is about more effective power to the ground transfer, not about driving aid.
BTW, I consider as driving aid various "parktronics"...and I hate them...
As far as smart, according to one IQ test my level is "above average"
I want to build a killer rear end ! FIREBIRDTONY Transmission - Rearend 7 08-03-2007 09:21 PM
Thump Thump in rear end?? HotRodMan Suspension - Brakes - Steering 7 01-24-2007 06:09 PM
38 Dodge rear end dwayne_tn Transmission - Rearend 5 09-09-2005 09:35 PM
Rear end identification help 71gtx Transmission - Rearend 1 11-07-2003 07:14 PM
eight inch rear end coupe1931 Transmission - Rearend 0 08-18-2003 02:33 AM
